Additional Interior Lights
Bronkee
8
20
Raleigh, NC
No
No
Has anyone installed additional lights inside their Bronco? I've seen YouTube videos and people make it look easy, but...I don't know if I'm going to try to do it myself or not yet. Has anyone taken your Bronco somewhere to have it done?
I have installed these, easy install and they work well. I reviewed them on the site.
LUMEN8 Tailgate Locking Storage Door with Light
LUMEN8 Grab Handles with Lights
Lumen8 Cargo Area Trunk Light
Lumen8 Rear Dome Light
The grab handle lights worked the best and i could keep my paracord handles with them.
I swapped out the 2 OEM front under dash lights that are controlled by the Ambient Lighting controls for a pair of color changing OEM F150 lights that are a direct fit and programmed Forscan to allow for color changing ambient lighting. I also added a pair of the same lights - 1 under each front seat as there are already OEM attachments for them. I did get a little lazy and bought a plug & play wire harness that taps into the front lights to power the rears - it’s an awesome upgrade.
My other interior lighting upgrade is this Chinesium unit from Amazon and it is surprisingly good.
  • #4
  • #5
Ok, that looks a lot less daunting than I saw on the YouTube video I watched. LOVE the amount of light too. Thank you!
I installed Mabett four piece LED dome lights over the top of each door, basically where grab handles get installed. The harness runs to the dome light in the rear so installation is pretty easy. I also replaced the rear dome light with the Manet unit. Far, far better overall than the stock lighting.
I have a strong dislike for pulling interior panels so I prefer simple when it comes to stuff like this. So far, no issues and work as designed.
Links:
