Are Portal Axles Really Worth It? - By Driving Line
TurboS44
11 minutes, very informative Portal Axle video by our very First BROTM winner, and our First BROTM repeat winner: @DesertChief
"In this episode of Chasing Dust, we’re discussing all the commotion around 74Weld portal axles and why they’re considered a game-changer for serious off-roaders. Portal axles offer unique advantages like lift without modifying your suspension, increased ground clearance, and a wider track width. They also provide straighter CV axles for IFS vehicles, improving performance over tough terrains."
"One of the biggest benefits is the gear reduction that portal axles deliver, which takes the strain off your drivetrain and allows you to run much larger tires. This means better traction and capability for tackling steep climbs, better MPGs, and correct shift points. However, these benefits come with some important considerations, especially around maintenance and cost."
"Portal axles require frequent upkeep, with 74Weld recommending a gear oil change every 5,000 miles, and the price tag isn’t cheap—expect to spend around $20,000 for all four corners. If you’re looking for a major performance upgrade and can handle the maintenance, portal axles might be the next big step for your off-road rig. Be sure to subscribe to Driving Line for more off-road tips, gear reviews, and insights!"
