CARBON FIBER GRAB HANDLE KIT & HOOD STRUTS - New Ford Performance Accessories - Lethal Performance!
jake@lethal
168
262
West Palm Beach, FL
2022 F-150 RCSB 5.0
Hey all!
Ford Performance just dropped some new accessories for 2021-2023 Ford Bronco’s!
BRONCO CARBON FIBER GRAB HANDLE KIT (FPP-M-7220-BCF)
These are the Factory equipment on Bronco Raptor with the Interior Carbon Fiber Pack.
The Kit includes:
  • LH Grab Handle -Carbon Fiber
  • RH Grab Handle -Carbon Fiber
  • Center Console -Carbon Fiber
With a super easy installation and added rigidity over the stock handles, it’s a great choice for those looking to upgrade their interior with some carbon fiber goodies.
Check them out here!
Ford Performance Carbon Fiber Grab Handle Kit (2021-2023 Bronco) - M-7220-BCF
BRONCO HOOD LIFT KIT (FPP-
M-16826-B)
Get rid of that crappy hood prop with some proper hood struts!
  • Lifts the hood approximately 8 inches above the prop rod height for more engine bay access.
  • Mounting brackets are zinc plated steel and feature a durable black powder coated finish for exceptional corrosion resistance while also providing a clean engine bay appearance
  • No Drilling Required. This kit includes all necessary mounting brackets and hardware and utilizes existing mounting holes and fasteners for an easy installation and OEM appearance
  • Backed by a Four-year warranty through Ford Performance.
NOTE! *Does not fit Everglades or Bronco Raptor*
Ford Performance Hood Lift Kit (2021-2023 Bronco) - M-16826-B
Of course, if you have any questions, looking for something in particular, or want to get something on order, feel free to reach out to any one of us here at Lethal Performance!
For once there's something I'm not tempted to upgrade....only because mine had the CF package from the factory. CF package not something I would have ordered myself but now that I have it I'm glad I do.
Any way to just buy the center grab handle and leave out the side handles? I stayed away from the carbon pack because with the top off and doors off someone can walk up with a screwdriver and make off $900 worth of carbon fiber in a matter of seconds. It does look good, but my paranoia got the best of me on that option.
You could get some security bolts from here that will make it much more challenging for theft.
Of you can go one step further and get your own custom keyed bolts
That will work, I likey, especially the Bryce! Thanks for posting. @DdYHrse we can find solutions to help spend the $. :giggle:
Side Note: for Bryce, minimum order is $100. If you don't want to spend that much, the other link I posted, Screwd, is their other division that sells in much smaller quantities, includes a special security bit (but is not your own 1 off custom bit)
Both options are great and I use them both.
Can you put those grab handles above to e window , like inside / side roof area. Or is that too much ? Just a question where is like to see a grab handle
The carbon fiber handles above replace the Ford Bronco and Bronco Raptor 3 grab handles, one on each side of the dash and one on the center console as pictured.
There are several interior corded handles for above the front door available in the after market. I have these solid interior above the door handles installed and like them quite well.
Oh yeah those look nice !! Thank you
