Ape Factory
Not seeing a maintenance or how to section on the forum so I'm posting it here.
I went and installed the Ford Performance rear differential cover and did a fluid swap on the front and transfer case as well. I used OEM fluids. I did everything with the car on the ground, no jacks.
Tools needed for the rear diff cover
I used 3/8 sockets for everything and have a small battery-powered impact gun which makes things go much more quickly
-10mm socket
-13mm socket, long
-13mm ratcheting box end wrench, straight
-15mm socket
-socket extensions as needed
-torque wrench
-flat blade screwdriver
-oil drain pan
Torque specs
-Differential bolts 29.5 ft.lbs
-drain and fill plugs 22 ft.lbs
Fluid
-Two quarts of Motorcraft 75w85 synthetic gear oil, p/n XY-75W85-QL
Parts
-Ford Performance rear differential cover for the Bronco Raptor, p/n M-4033-DR
The Braptor has three wiring loom brackets on the diff itself. I removed those along with the two on either side of the differential so I had more clearance to work. The two outer brackets on the axle are a bit of a pain to get off but a flat blade screwdriver helps. The clips/brackets on the studs pull off fairly easily.
I loosened the three studs first using the 13mm ratcheting box wrench. Once they're loose, you're able to use a 13mm long socket and an extension with the impact gun to get them off. The 10mm come off easily and there's really no reason to work them loose in a cross pattern. Once two of the bottom 10mm bolts are removed, fluid will leak out so make sure the drain pan is in place.
The fluid wasn't too dirty and still had an amber hue to it although there were lots of ultra fine particles which as we all know are a result of break-in.
Photo of the stamp on the diff just for sh*ts and giggles.
With the fluid drained, clean the mating surface on the differential case AND the cover. Carb cleaner works just fine as does denatured alcohol on the new cover. I'm using the included fiber gasket as I don't intend to take the cover off anytime soon. I'm sure Fel-Pro or someone else will have a replacement gasket for those who need it. I forgot to shoot a photo of the gasket itself to see who the manufacturer is.
Follow the included instructions for the tightening sequence and torque specifications. Make sure to tighten the drain plug to specification before filling!
There are two fill ports. Since the diff has had fluid in it before, you'll use the bottom port. There's enough room to simply use the bottle to squeeze the fluid in. For the first fluid container, there was a bit left at the bottom using this method and I simply dumped the remaining amount into the second bottle. Once done with the second bottle, and given there's some left over at the bottom, I went to the third bottle. A bit of fluid will drip out once you've reached the proper level.
Install the drain fill plug, torque to spec. Re-attach all the wiring loom clips and you're good to go! It took me about 40 minutes, taking it slow, to install the cover. I do believe the FP cover requires more fluid vs. the OEM cover. I purchased three quarts and it was enough for the rear and front differential. Even though I moved on to the third bottle, there was enough for the front diff once the rear was filled.
-10mm socket
-13mm socket, long
-15mm socket
-torque wrench
-oil drain pan
Torque specs
Fluid
Parts
