**** NEW - BRONCO RAPTOR - MID TRAVEL SUSPENSION KIT *****
GregFoutz
34
109
Mesa, AZ
Gen 3 Raptor
Check out the first true Mid-Travel kit for the Bronco Raptor on the market. The kit features a fully fabricated lower arm that incorporates a second shock mount for the custom Fox 3.0 bypass shock. The kit uses our standard Billet upper arm, and we add a fabricated bypass shock tower that also provides strength to the front coil tower. The kit works with the stock electronic sway bar kit with just a new sway bar linkage. You can add our front bump stop and limit strap kit for the full package. check out the details.
https://www.foutzmotorsports.com/co...-front-long-travel-kit?variant=45592185897172
Ford Bronco ***** NEW *****  Bronco Raptor Front Suspension kit - Mid Travel kit Bronco-Raptor_midtravel
Sponsored
Very cool! Are you going to do a long travel kit as well? Also what about the rear?
down the road we will do a plus 3 kit yes but it will be a while. havent even started on the CAD work for that kit.
looking at options to add a 2nd shock to the rear now. We have the add on hydraulic bump stop kit that helps a bunch and we can re-valve the stock shock to improve that quite a bit. Thats what I have on our Bronco Raptor now.
Anyone pull the trigger on this yet? Would love to hear impressions on the secondary shock.
