Welcome to BroncoRaptor.com!Anyone know the width when using the wheel in beadlock mode
It seems 8.5” in regular form
But I’m guessing 9.5” in beadlock mode?
I’m thinking same,Welcome to BroncoRaptor.com!
approximately 9" width when using beadlock ring. I have not had a tire removed from the wheel yet to measure, but it would be the 8.5" plus the width of the outer wheel lip with beauty ring removed.
Agreed, maybe somewhere between 1/2-1" increase. It could be measured when the tire has been dismounted and a Ford Beadlock ring is set on the wheel as the Ford beadlocks appear to actually make contact with the wheel after mounting and torquing. Below is a good install video.I’m thinking same,
I’d like to get bigger tires but I see some sites say minimum or 9” or 9.5” rim
I’d be running them in beadlock form
But have not had a chance to remount a tire on mine to measure
I’m thinking the space thickness or the tire too
Like from inside to outside swap would give you about 1/2” thickness of tire + the 3/8 Ish ? Of the rim wall
So maybe a 1” total increase
