I haven’t noticed that on mine but I would suggest:I’m wondering what you guys do to keep the top front bolt attachments from damaging the paint on the frame? Are there protective stick-ons I can buy?
everything within it’s limit. Service manual torque spec on those bolts is 106 in/lbs (9 ft/lb). Interestingly, the user manual says 15 ft/lb (+/- 2ft/lb). In either case, leave the breaker bar in the tool box3 - tighten that bolt more because the missing paint is from rubbing which means there was some movement.
