WeatherTech Ford Bronco Raptor MudFlap - install & Review - By HookedONBronco
3,963
13 minute front installation review with walk around post installation. Note that I always carefully try to unscrew the OEM push pin screw before removing for ease of pin removal.
"WeatherTech Ford Bronco Raptor MudFlap - install & Review
A fully explained installation Guide for WeatherTech’s front MudFlap for the Ford Bronco Raptor. If you’re seeking an end to the grippy front tire’s assault on the Raptor’s body sides and doors - mud, gravel, salt, ice, etc.; this is a great and easy-to-install solution. Can be done in about 30 minutes total - no-drill. The result is a very solid and OEM type of look and quality.
The product is available direct from the manufacturers here: "
