🌎 Bronco Raptor Forum Member Map is live!
The Bronco Raptor Forum member map is now live!
Check out the new Bronco Raptor Forum member map to view members in your area. Due to privacy concerns, this is not precise, just an approximate location based on your IP address. This is for members only! You must be a registered member and logged into the forum to view the map.
This can be accessed under the Member link in the navigation bar or click here! https://www.broncoraptor.com/membersmap/
I’m in CT but don’t see myself or any others in CT.
I'm not finding myself at the IP address saying I'm in Seattle, WA. I'm using Starlink which my substation is somewhere around there. I'm really in Prineville, OR.
I'm seeing you, but the text is hard to read. I should be able to fix that.
  • Like
Reactions: SBP
It’s likely your Starlink internet provider actually hits the internet in Seattle area. That’s the tricky part. You are on Starlink’s private network until you drop out to the internet. Which is where the location comes from.
  • Like
Reactions: SBP
I guess I'm just lurking around in the shadows as usual 😜
Thanks for finding me. Maybe if I quit my denial of needing readers, I could actually see something.
So it's based on public IP adress, so I'm assuming if we are traveling or if we move, it will move with us?
