Beadlock capable type 2
Ford does sell the beadlock rings. They’re $770 and you can get 15% off with their promo.
Careful, if it’s says trim kit, they are not the actual beadlock rings, they are the beauty rings. Also, if it says wheel kits…. It’s one wheel with one ring…..
These are the ones you want from ford.
I went down this rabbit hole, don’t make the mistakes I did.
This link is to the Bronco bead lock trim kit in all black like the one standard on 1st edition and Wildtrak models.
However cardad is correct with the price and they are available from Ford Performance Parts (off road accessories)
Bronco Sasquatch wheel bead lock kit:
Raptor 37" wheel bead lock kit, doesn't specify Bronco Raptor wheels yet, but I would expect soon:
I think your paint options for the bead-lock rings depend on how you plan to use your Bronco Raptor. If it's mainly going to stay on-road and not see off-road rock crawling, then I would say powder coating would be a good way to go. If you're going to be doing lots of off-roading and you think the rings will take a lot of abuse, then I would just paint them at home. That way you can always pop them off when they get dinged up and repaint easily.
Does anyone know if the Sasquatch bead lock capable wheels are the same as the Braptor headlock? If not, will Sasquatch wheels fit on the Braptor?
That's a good question! It would be nice for those who have already purchased the bead lock rings for the Bronco to be able to move them over to their Bronco Raptor and not have to buy a new set.
Wheels are not compatible. Different bolt pattern.
from Ford Performance they are showing same part number for functional bead lock kit for both Raptor and Broncos. M-1021K-BL5
Perfect, thank you!
