Bronco Raptor Stock Wheel & Tire Specs
Not bad at all! It might be tough to find another 37-inch tire that weighs less than that.
These are load range C 6ply tires, load range D are 8ply and weigh about 69lbs. Don't really need D for the Raptor, never have the need for 3550lbs /tire
Our Bronco Raptor Forged Beadlock-capable OEM wheel weights about 36.4 lbs. 17x8.5 with +34 positive offset.
Weighted the spare tire/wheel combo on a bathroom scale, maybe not the most accurate so I tried a dozen times. highest was 102.2, lowest 101.4, most common was 101.6 reading.
So, if we use 101.6
minus 2.25 oz wheel weights, -.14
minus 3 oz for motorcraft TPS, -.187
minus 64.8 lbs for the KO2 according to BFGoodrich site.
Totals to approximately 36.4 lbs., a little lighter than I expected.
Our Bronco Raptor Forged Beadlock OEM wheel weights about 36.4 lbs. 17x8.5 with +34 positive offset.
So, if we use 101.6
That's a lot more offset than I thought it would be. So if my math is right then 0 offset aftermarket wheels will poke out about 1.3-inches more per side than stock wheels?
Yes
So im looking to buy the beadlock rings for my stock wheels....but also for a street set ....im looking at the icon compression wheel in titanium....17x8.5 6on5.5...my question is i only want to go out a liitle bit more than stock...i saw the 0mm offset moves it out 1.3 inches....so im terrible at math...so i would assume the 25 mm offset would only move the wheel out about 1/2 inch or so?
Any chance we can update the OP with the correct numbers (offset especially) to avoid confusing new owners like me 😇
Bronco Raptor Cast OEM wheel weight: 28 lbs
Bronco Raptor Cast Beadlock-capable OEM wheel weight: 36.6 lbs
Bronco Raptor Forged Beadlock-capable OEM wheel weight: 36.4 lbs
I did a good deal of searching but couldn't find the weight difference between the OEM beadlock-capable wheel options.
Update: An eBay seller told me the weight of the stock and cast beadlock-capable wheels. Please let me know if either are incorrect. I am surprised that the forged wheels are slightly lighter.
