A member of Bronco6g captured a Cactus Gray Bronco Raptor out in the wild! It was so wide, it couldn't even be captured in one photo
are you saying the headlocks have different offset than the stock wheel? (the 'pushed out 1/2 inch comment)At Ford Media event in Palm Springs, originally posted on Bronco6g by our own member "Antimatter Blue" Thank you!
Note that Beadlock Rings installed on the Style1 beadlock wheels and they do look noticeable wider being pushed outward approximately 1/2 inch. Also front bumper end caps and fog lights removed.
When using a beadlock ring kit, the outside tire bead is placed on the outsite of the wheel lip then the ring is bolted on to pinch the tire bead between the outside lip of the wheel and the beadlock ring. This effectively adds approximately 1/2" of outward wheel width thereby moving the tire outer edge outward probably something slightly less than 1/2". In the photo's it's possible to see the added width of the tires as well as the vertical relationship to the fender flares. The tire effectively now thinks its mounted to a wheel wider than 8.5". Also notice in the photo's the stock wheels with the beauty rings have a small gap to the tire, whereas after a beadlock ring is installed there is no gap since the ring is pinching the tire bead.are you saying the headlocks have different offset than the stock wheel? (the 'pushed out 1/2 inch comment)
ah, I missed the fact that they had the beadlock rings installed on the wheels.When using a beadlock ring kit, the outside tire bead is placed on the outsite of the wheel lip then the ring is bolted on to pinch the tire bead between the outside lip of the wheel and the beadlock ring. This effectively adds approximately 1/2" of outward wheel width thereby moving the tire outer edge outward probably something slightly less than 1/2". In the photo's it's possible to see the added width of the tires as well as the vertical relationship to the fender flares. The tire effectively now thinks its mounted to a wheel wider than 8.5". Also notice in the photo's the stock wheels with the beauty rings have a small gap to the tire, whereas after a beadlock ring is installed there is no gap since the ring is pinching the tire bead.
Thread on this forum with video of Beadlock ring kit on a Raptor
It’s like da widdle bwotha!
That can't be a Sasquatch-equipped Bronco, can it?! The Bronco Raptor makes it look like a Bronco Sport
No kidding. I’ll try to take some good shots of the SAS I’m trading in next to the BR, for comparative purposes. Should be any day now.That can't be a Sasquatch-equipped Bronco, can it?! The Bronco Raptor makes it look like a Bronco Sport![]()
Funny, my dealer had a salesman say that exact same thing, “when did we get 2 Bronco sports in?”That can't be a Sasquatch-equipped Bronco, can it?! The Bronco Raptor makes it look like a Bronco Sport![]()
33s VS 37s LOL wow what a difference
