Dual battery anyone?
pk9394
27
38
NY
Does it necessary to do dual battery for winch? I looked around the best system is Genesis offroad dual battery kit, with 2 Odyssey batteries, the cost is nearly $1400, thats way too much to use the winch only few time a year!
or should I just replace a better battery like optima yellow top.
anyone had the detail spec on the oem AGM battery in the our car? I only know is group 94R
I don’t think a dual battery setup is necessary for a winch. Unless you are using the winch without the vehicle running (i.e. alternator charging the battery) for an extended period of time, you should be fine. According to the specs, the Warn Zeon 10 winch pulls 409 amps at max load which is significant but not beyond the H6 battery limits. 👍🏼
that's what i thought, most likely i will drop a yellow top in it next year
