" In todays video we check out the process for removing the roof and doors on the all new Ford Bronco Raptor! This has been such a fun SUV for the week that we had it so be sure to check out the rest of the content we have created on this almost $100K SUV! For the removal process, it is very easy, just a bit time consuming! Starting with the doors, make sure that the windows are all down first and that you place the bags on each door to keep them better protected and it's just easier to start with that. Each door has only two bolts that need to be loosened using a 13mm socket. With those removed, the electronics must be disconnected and you can also push the side mirror out of the way for more wiggle room. And it's just that easy to lift up the door and take it off! The roof panels are super simple, all the tabs need to be unclipped and for the front passengers, start on the driver side, then remove the passenger side. Then you can remove the rear passenger top piece! From there the entire rear section can be removed after loosening and removing the 10 bolts holding it in place!"
Related to these 5 additional review video's from Bros FOURR Speed:
www.broncoraptor.com
![www.broncoraptor.com](https://www.broncoraptor.com/img/bronco-raptor-opengraph.jpg)
Taking Delivery of a Brand New Ford Bronco Raptor! *First Impressions* - By Bros FOURR Speed
" This will be some fun! Check out the all new 2023 Ford Bronco Raptor! This is the new off road focused high performance Bronco wearing that Raptor badge! Today I take delivery of the new Ford Bronco Raptor and get my first impression son driving it and experiencing what the Raptor version of...
![www.broncoraptor.com](https://www.broncoraptor.com/favicon-32x32.png)
2023 Ford Bronco Raptor | Point Of View Walkaround, Test Drive and Review - By Bros FOURR Speed
"Take a look at the all new Ford Bronco Raptor! The Raptor name has been added to this new retro Ford Bronco and it takes everything up a notch! The Raptor Bronco has a high output 3.0L EcoBoost V6 with 418 horsepower and 440 pound feet of torque. The Raptor Bronco also has several drive modes...
2023 Ford Bronco Raptor: Start Up, Exhaust, Walkaround, POV, Test Drive and Review - By Bros FOURR Speed
Taking The 2023 Ford Bronco Raptor Off Road! It’s Better Than A Wrangler 392 Rubicon! - By Bros FOURR Speed
"We have the keys to this 2023 Ford Bronco Raptor, so naturally we went off roading! How capable is the Raptor Bronco off road? This new Bronco Raptor was awesome! While the loaded Ford Bronco Raptor costs over $90,000, it is so confident hitting the rocks ands trails it just felt so at home! I...
2023 Ford Bronco Raptor POV Rock Crawl Mode Off Road Test Drive! - By Bros FOURR Speed
"Take a full point of view drive up some gnarly rocks in the 2023 Bronco Raptor! Full POV of Rock Crawl mode in the Raptor Bronco driving up some massive rocks! We have the keys to this 2023 Ford Bronco Raptor, so naturally we went off roading! How capable is the Raptor Bronco off road? This new...
