M&R Automotive dual functioning LED lighting options
I have not purchased these, however as seen in the below video's they appear to be complete kit options for our Bronco Raptor.
Link to M&R Automotive Bronco Raptor LED dual functioning fog lights and light bar kits.
Ford Bronco Raptor LED Fog Light kit Installation by M&R Automotive​
Ford Bronco Raptor 30" LED Light Bar Modular bumper Installation by M&R Automotive​
New 2022 Ford Bronco Raptor 40 In Light Bar Installation by M&R Automotive​
New Ford Bronco Raptor M&R Dual Function Ditch Lights Hood Mount Light Pillars​
Below is 3 quick Overview video's of above M&R lighting options.
Overview of the M&R Dual Function 40in Light Bar for the New Bronco Raptor​
Overview of M&R Dual Function Light Pods Hood Mount Pillars White LED with Amber DRL backglow​
Overview of the M&R LED Dual Function Fog Light For The New Bronco Raptor​
2002 Ford Bronco Raptor 40in Roof Light Bar Install by M&R Automotive​
Showcase 2002 Ford Bronco Raptor 40in Roof Light Bar by M&R Automotive​
Bronco Raptor with a 40in Light bar & fog light kit from M&R
2022 2023 Bronco Raptor Light Output with M&R Automotive Light Kits​
How to remove Rigids OEM fog lights from 2022 2023 Ford Bronco Raptor by M&R Automotive
2021 2022 2023 Ford Bronco/Bronco Raptor LED Fog Light kit Installation by M&R Automotive
"⚒️Full install of M&R Automotive fog light kit for 2022 2023 Ford Bronco / Bronco Raptor . Mike shows you step-by-step: removing rigids fog lights, install the M&R fog light kit and how to wire.
✌️The Ford Bronco modular bumper light fog opening light kit is here. It houses 8 x 20w square lights totaling 160W of power. It has a shroud that is powder coated to give it an awesome effect. The square lights also offer amber backlight DRL to match the rest of the Bronco marker lighting. The kit is rated at 16,000 lumens all together.
Check out the complete M&R Automotive catalog https://www.MandRonline.com."
2021 2022 2023 2024 Ford Bronco /Bronco Raptor 80w Bull Bar Light Kit Installation by M&R Automotive
"⚒️Full install of M&R Automotive Bull bar kit with 5x80w pods for 2021 2022 2023 2024 Ford Bronco / Bronco Raptor.
Mike shows you step-by-step: installing 80watt pods onto the bullbar and all wiring
✌️The Ford Bronco modular bumper 80watt bull bar light kit is here. It consists of 5 x 80w square lights total of 400W of power. The bullbar is aftermarket and powder coated. The light pods have white main light with amber DRL backglow.
📦WHAT YOU GET?
(5) 80watt light pods
(1) Bull Bar Mount
M&R wiring harness
👌Please note that this product is for offroad use only. Please check your local regulations about street use.
0:00 - intro
0:12 - install pods to bullbar
2:11 - wiring of pods
7:07 - install on Bronco
7:46 - wiring to AUX
2021 2022 2023 2024 Ford Bronco /Bronco Raptor Light Output of 80watt Pods by M&R Automotive
"✌️The Ford Bronco modular bumper 80watt bull bar light kit is here. It consists of 5 x 80w square lights total of 400W of power. The bullbar is aftermarket and powder coated. The light pods have white main light with amber DRL backglow."
I ordered the pillar lights this week. They look solid and I like the DRL built in. Will update once they are installed.
2021 2022 2023 2024 Ford Bronco/Bronco Raptor Ditch Light kit - "Boomerang" by M&R Automotive
"Full install of M&R Automotive ditch light kit for 2021 2022 2023 2024 Ford Bronco / Bronco Raptor ."
"Mike shows you step-by-step: install the M&R ditch light kit and how to wire."
"The Ford Bronco modular bumper light fog opening light kit is here. It houses 6 x 20w square lights totaling 160W of power. It has a mounting plate that is powder coated to give it an awesome effect. The square lights also offer amber backlight DRL to match the rest of the Bronco marker lighting. The kit is rated at 16,000 lumens all together."
2021 Ford Bronco, Ford Bronco Raptor 30in Light Bar PRO | Easy Install | By M&R Automotive​
"️Introducing our 30in Light Bar PRO on the Ford Bronco/Ford Bronco Raptor with modular bumper.
Mike, takes you step by step through the installation process. Our kit is designed for a seamless bolt-on installation right on top of the bumper, reusing factory bolts. Plus, follow along for AUX switch wiring step-by-step. "
2021 Ford Bronco, Ford Bronco Raptor 40in Light Bar PRO | Easy Install | By M&R Automotive​
"️Introducing our Curved 40in Light Bar PRO on the Ford Bronco/Ford Bronco Raptor with modular bumper.
Mike, takes you step by step through the installation process. Our kit is designed for a seamless bolt-on installation right on top of the bumper, reusing factory bolts. Plus, follow along for AUX switch wiring step-by-step."
