Recovery Gear-Onboard Air
bourbonbill
58
81
North Carolina
Hey all,
Well with the flow of braptors starting to show up, I figured I would pose a couple questions.
1) What recovery gear are you planning to buy. Type and brand.
2)Are you planning to buy an air supply to Air up/down. Type and brand.
Anyone know what we will be able to do wench wise with the braptor? With the bumper and different bash plate I haven't seen any info.
again-type and brand please.
If you want to share links and pricing, where to buy etc. please do.
Hey all,
Covering a lot of territory!
Recovery gear will be Factor 55. It’s high quality, while not cheap it’s comparable to Bubba, Yankum etc, and discounted when buying direct from Factor 55. Although for the number of times I’ll probably use it, lesser brand would likely suffice.
I will order an ARB twin portable once my truck gets built on the 26th. Anything less powerful will be a chore reinflating 37s. Im going portable as the 3.0 turbo routing and air intake system appear to preclude using the typical spots to bracket mount under the hood. Even if there is room, I’m Not anticipating anyone making Raptor specific brackets anytime soon. Volumes are too low.
There is the soon to be released or just released under spare tire bracket, but also unclear if that will work with Braptors reinforced tailgate and different mounting position.
A portable will just plain work, could mount it later if a good option is available and I can use it in the Defender too.
Winches, there’s another thread on winches, but I’m going with JCR winch plate and camera relocation bracket. It’s designed for modular bumper and JCR doesn’t foresee issues with BRaptor. It has parking sensor relocation holes, works with ACC, and unobstructed camera view with relo bracket behind Fairlead.
Warn Zeon 12 S and Factor 55 last link complete the front end. 12000 lb since the BRaptor weighs so much. Flat link fir closed system .
I’ve had a lot of time to ponder this waiting! Good luck with your fit out
John-All great info Thanks.
My plans are quite similar. American Adventure Lab may have a mounting solution for the ARB twin compressor in the rear cargo area (which I think is the same as the normal Bronco?), so I'm going to check that out. Will also keep my eye on that spare tire bracket solution to see if that pans out.
Agree totally with your Warn and Factor55 picks, though I'm planning to mount them on a BAMF front bumper (they also can take care of sensor/ACC relocation). I've already got some other Warn recovery gear (in terms of soft shackles, snatch block, recovery straps, gloves, and so on ).
I don't see the need at this time for any additional undercarraige armor. Looks pretty substantial from the photos/videos I've seen. Limb risers might be a consideration depending on where I go wheeling, and I may consider getting the AR Ruggedized Trail Sights to handle beefier loads/tensions on the risers.
it’ll be nice to turn our plans into reality!
Couple thoughts on the under tire mount Option. i saw somewhere that the maker has made modifications to make the air connect positioning more flexible to accommodate a wider range of wheel options. I’d like to assume this will work on any OEM Raptor wheel, but I’d do plenty of due diligence on that especially if you will or might go with an aftermarket wheel.
My primary concern is cleaning around the compressor (especially filter) under the mount and behind the wheel. I think this might be a factor to consider for anyone who is off road enough to want an onboard compressor.
additional benefit of portable is the small 1 gallon air tank which should facilitate faster inflation and air tools, but the big downside (which I’m dumb enough to do) is leaving it at home.
Or forgetting to refill/recharge them!
I was thinking about the ARB twin on-board air compressor (CKMTA12). A friend has one which is mounted behind the spare tire mount; a very clean look. That is not an option for me since I have the JCR vanguard dual-swing arm rear bumper.
I ended up with an EZ Flate M.O.A.B. portable 10.6 CFM dual air compressor and a 4-tire inflator hose. It was about half the cost of the ARB and I can swap it between vehicles. It can fill all four 33" Jeep tires in 6.5 minutes going from 14 to 40 psig. No overheating. I imagine the BRaptor 37" tires will go longer. The compressor is loud, but that is the only downside other than storage room inside the rig.
Let's see where to start. Recovery wise I went with some shackles on the front hooks I got from Amazon and a Factor 55 hitchlink on the rear with a warn epic d ring on it. I also picked up a safe jack 6 ton bottle jack since I didn't want to mount a high lift to it. I also adjusted the mount on an H3R fire extinguisher (1lb) and mounted it to the rear roll bar. I took this thing to Moab so I wanted something to air up and down tires with. I opted for the ARB single compressor in the carry box. I also got a digital air gauge to help. The single compressor was able to air up all 4 tires from 20 PSI to 40 PSI in about 12-15 minutes. Not too bad. You just pop the hood, hook it up to the battery, and start pumping air. I am sure the twin could do better speed wise. I doubt I will be using it all the time so I opted for something I could just grab and go with instead of permanently mounting it. Either way I would have to carry some kind of box to put all the hoses and gauges in anyway so I wasn't going to save a ton of space by mounting it for good. If you really want to air up and down fast I would suggest the twin with the little tank. I bet that thing could do work and you would have an option for air tools. That may be something I look into a few years down the road. Winch wise I have been on the fence with one. I would like to have one, but I also don't want move my cruise sensor, relocate the camera, etc. If I do get one though I plan to use what I can with the factory bumper. I think I have pretty much decided the after market stuff isn't really much better than what it already came with.
I've been considering getting a portable tire inflator that doubles as a power station. This way, I have a nice air compressor to adjust tire pressures if needed, but I can also use it to recharge/power my electronics. Fanttik has a lot of good reviews. Has anyone used their products?
  • Jet-inflate: In just 38 seconds, watch as the flagship inflator effortlessly breathes life into a 33 inch truck tire, precisely reaching the optimal 30-35 PSI with an accuracy of 1 PSI
  • 3-in-1 Companion: X9 Ultra seamlessly combines a tire inflator, a 92.5 Wh portable power station, and a powerful flashlight. It provides a stable power source for drones, laptops, smartphones, and more, as well as lighting up your campsite
  • Powerful Battery Life: Equipped with a large battery, this inflator can refill 25 pickup tires up to 33 inches (from 30 to 35 PSI) on one charge. It can also fill 4.5 pickup tires (from 0 to 35 PSI) on a single charge
  • Four Customizable Modes: This tire inflator boasts four user-customizable modes (M1/M2/M3/M4), allowing you to record and recall your preferred pressure levels effortlessly. Just set the PSI, hit start, and walk away
  • Long Air Hose for Pickup Truck Tires: An ultra-long 45 inch inflation hose is seamlessly stored at the bottom of the inflator, accompanied by dedicated storage space for accessories such as a presta valve adapter, ball needle, and swim ring valve
  • Disclosure: This post contains an affiliate link. If you click on this link and make a purchase, we may earn a small commission at no additional cost to you. Your support through these links helps to keep this content free and accessible.
I am a Milwaukee cordless tool fan and have “standardized” on their M18 products. When going off pavement, I bring an M18 compressor, M18 impact wrench, M18 chainsaw and a few XC 8Ah batteries. Milwaukee also makes an AC adapter but I use the vehicle for charging electronics. (I travel heavier than needed but, I would rather have it and not need it instead of needing it and not having it)
