Ford Performance Air/Oil Separator DIY installation
4,043
Installed the Ford Performance Air/Oil Separator SKU: M6766BW30 and removed my previously installed UPR single valve catch can. If I would have had the UPR dual valve I don't think I would have seen the value in changing to this Ford Performance unit.
If your tackling this install project yourself, this Top Side creeper makes it much easier as the Passenger (R) side canister is centered on top of the engine at the back.
The Ford Performance Installation instructions are well written and provides clear photo's.
The Passenger side, shown below, seemed easy and quick enough.
When I got to the Drivers side, the OEM air tube, that this kit replaces, has tamper proof fittings that will break during removal. Then on page 7 of the instructions it recommended to remove the vertical air intake tube in order to remove the air tube lower fitting. This appeared to be the most difficult and time consuming part of the installation. I decided to try removing the lower tamper proof fitting using the pliers shown below which worked quite well and saved a bunch of time in disassembly. Simply grip the pliers with right hand and hold the intake air tube with your left and pull straight up. This technique was easier for me as I was looking straight down from the top side creeper.
Highlighted below upper and lower connection ports.
Then on to the drivers side bracket install, first obstacle was the ground cable path was where the canister mounts.
I removed the ground cable, rerouted between vacuum hose and wiring harness, added wire looming wrapped in electrical tape on the ground cable, then zip tied to wiring harness to hold in place.
Drivers side with supplied hoses attached, I did carefully pull the HVAC line towards the brake fluid reservoir to provide adequate clearance from the canister, thank you to @Roughstock post here.
Completed photo below:
The passenger side canister outlet tube is closer to the hood liner than I would like, curious if others have noticed any abrasions in the "Ford Performance" area on the liner. Pic below take from drivers side front corner with hood closed between latch and safety latch allowing enough space to take the photo below.
Excellent write up!
I checked today and.......yep its a rubbing.
When I opened the hood there was a white mark at the back as you can see where the catch can meets. Also a very light rubbing of the hose. i wouldn't even call the hose rubbing. Amazing I didn't notice this the other day when I was emptying the catch cans.
That white mark is concave from the rubbing. In these pics it is a bit cleaner as I took the dust off with my fingers.
As you can see there is considerable rub. When I had the rattle issue when these were installed I reported this catch can, when in drive, shakes a real lot. It vibrates more than you would think. I did a visual inspection of this can while vehicle in drive. Of course the rattle has nothing to do with this catch can as discussed. The vibrating; however, is an issue.
I am hoping the rubbing has stopped since it may have rubbed its way clear of the hood with the concave white spot and the can being rubbed down.
It will be interesting to know what you think and any fix that may be appropriate.
Excellent write up!
Oh no, that's way more contact than I expected. Yours has not stopped rubbing, the engine/powertrain has quite a bit of movement. I'm going to look at modifying the canister bracket to get it as low as possible, from your photo's it needs to be 3/8" to 1/2" lower, that's my goal. Nice you had the dealer install yours as they will need to fix it and it'll be obvious to them.
I'm sure this wasn't Ford Performance's intent, be nice if they sent us updated replacement brackets.
Thank you for posting these photo's
Thanks for the input. I will contact my dealer and get it sorted.
Look forward to seeing your solution.
I've contacted the dealer hopefully get it fixed next week. At the same time I will get my 30k coolant flush, brake flush and transmission flush done. Good to keep the fluids changed.
They said it would be an easy fix for the catch cans. I will send them some pics.I will post the fix for the can. Just waiting to hear back if I can get in next week for the flushes.
I've contacted the dealer hopefully get it fixed next week. At the same time I will get my 30k coolant flush, brake flush and transmission flush done. Good to keep the fluids changed. These days the flushes seem to be excellerated. On my BMW GS Adventure they want to flush the brake fluid quite regularly. They say it has to do with the ABS.
What's a boy to do. Fluid changes are important so I do follow the schedules, excellerated for money or not. Hard to know these days what is actually happening to the fluids.
They said it would be an easy fix for the catch can as expected. I will post the fix for the can. Just waiting to hear back if I can get in next week for the flushes.
I looked at it closer today and decided to call Ford Performance Techline on Monday. This is a FP problem so I'll let them investigate and determine a solution. I feel if I modify any part the kit then I've taken ownership of the problem, one that I don't see an easy solution. The back of the canister top touches the hood before the hood is even completely closed. Both canisters are identical, so they aren't switched and the canister can only be lowered by maybe 3/8" before resting on the fittings below, this still doesn't seem enough, especially considering the intented off road usage. Fortunately I won't be driving mine until spring, in Michigan that's typically end of April beginning of May.
If you have the original air tube that this kit replaces, I would consider removing the air/oil separator canister and attached air tubes but leaving the bracket and replacing with the original tube to prevent any further damage. I wouldn't expect any problem leaving only the drivers side canister installed.
Yeah I don't have the original air tube. On Monday I will be hearing from my guy with an appointment to do all the flushes and the catch can fix. Or just the catch can fix if they can't get me in to do the flushes.
I will ask him to ask the Head Mechanic/shop foreman to call Ford Performance as well prior to my visit. Rather than having him figure it out on the spot. That is a great idea.
Please let me know if you get any answers from Ford and I will keep you updated on the dealership fix. Jim Click in Tucson. I go to this dealership specifically for Ford Performance installs since they have qualified mechanics for this. Ryan runs Jim Click Customs where they do all kinds of modifications. He is a great guy. I did my rims, some more PPF, ceramic and the pro cal and catch cans there.
I have an appointment Thursday. I am hoping they contact Ford Performance. I spoke with Ryan and he said he would take it to the mechanic. He said he may not be able to talk with them till Thursday. I requested they do it now and he understood. We will see.
Also getting brake, transmission and coolant flushes.
I have an appointment Thursday. I am hoping they contact Ford Performance. I spoke to my guy and he said he would take it to the mechanic. He said he may not be able to talk with them till Thursday. I requested they do it now and he understood. We will see.
I spoke with FP Techline and was asked to send them an email with photo's. Email was just sent, containing description, link to this thread, and additional photo's so they can visually confirm my Passenger side installation is correct along with interference. I also mentioned @Roughstock photo's above showing damage after ~1700 miles. This email is expecting to go to Ford Performance Engineering for analysis.
My vehicle is currently in the shop for a couple of weeks getting Xpel Ultimate Plus 10 PPF.
Just before getting it into the shop last week, I had the FP Carbon Fiber hood cowl (gloss) and a Turbosmart dual port blow-off valve installed. So I had the hood open and I took some pics, but none capture this damage area.
So I will have to take a look when I get it back next week. I will let you know.
I looking forward to hearing what @Roughstock's dealer says.
My mechanic did contact Ford Performance the other day. So they may have gave him some direction already or perhaps he will get some by tomorrow when they are hopefully performing the fix. Tomorrow is brake, trans and coolant flushes and they know the priority is the catch can fix. Looking forward to updating everyone tomorrow night.
great write up and pics!
how much did you guys pay for the dealer to install the catch cans, turbo smart, and hood cowl?
thanks so much. and that seems super reasonable for all of it wow!!
I thought all these flushes were very quick. This dealer recommends brake flush only at 30k. Which I am doing today with the catch can fix. Transmission flush at 100k and coolant at 60k. This seems more reasonable. So it seems Ford does not recommend coolant and transmission flush at 30k. I should look at the manual and its recommendations; however, I was just told Ford does not recommend coolant and transmission flush now.
From the manual. Also, it says brake fluid every three years. So doing brake fluid now is OK. Amazing the one dealer saying 30k for transmission fluid and 30k for coolant flush when the numbers below are way different.
Ford did reply to the dealer mechanic and told him to tighten up everything. Bolts and such. That was their remedy for today. The mechanic sent them pictures of the current situation and they said this is the first time this issue has come up.
Perhaps there are very few who actually use this vehicle the way it is intended and perhaps they have not sold a lot of these. Anyway the mechanic said that sometimes they get back to them quickly and sometimes they don't. He said today they got back to him quickly perhaps because he had already contacted them about this situation earlier in the week.
So for now it is a zip tie till Ford Performance has a fix. The dealer did not have my old hoses kicking around so this is it for now. I just off roaded and bounced around a lot and the can hasn't moved or come free with the zip tie. I explained I will be off roading a lot at KOH very soon and they believe this should be fine for now. It seems so. He also put some felt tape on the can as you can see.
  • #18
I'll reach out to F.P. again and ask for my case number from my email, based on what your mechanic was told it may not exist yet, and without a case number, as you found out, nothing will show up in Ford's search.
The zip ties will hold if properly secured, it's amazing the punishment they can withstand on an engine.
Thank you for posting their temporary solution.
