- May 25, 2022
- Sacramento/Tahoe
- 2022 Bronco Raptor
- Current Ride #2
So I had a two blow out fiasco in the desert where I was surrounded by Broncos but couldn’t use one of their spares without swapping tires off bead locks.
So i have been looking for a belt and suspenders approach to spare tires.
First was Bead grips sidewalk kit. Now I slit a two pack of wheel adaptors with a fellow Raptor owner. About $70 for two.
It’s compact, reasonably light and allows me to run a 6x5.5 wheel. As I’m usually running with two or more Broncos on 37s, this gives me a doomsday scenario option when heading way out in the desert.
lugnutguys.com
Wheel Adapter- Converts 6x135 to 6x5.5 - 1.5" Thick 14x2 Studs 87.1mm Hub
Wheel Adapter- Converts 6x135 to 6x5.5 - 1.5" Thick 14x2 Studs 87.1mm Hub. Shop 6x135 to 6x5.5 Wheel Adapters & Wheel Spacers at Lug Nut Guys. Bolt patterns and sizes to fit most vehicles. Aircraft grade precision machined aluminum. Change the bolt pattern, space out the wheels. Fast, Free...
