  • #781
Follow-up on the Moab trip . . .
Golden Spike - Golden Crack
(reduced to 480p)
Steel Bender - The Wall (reduced to 480p)
Steel Bender - Dragon Tail (reduced to 480p)
View attachment 10354 more scary than it looks
View attachment 10356 Upper
View attachment 10357 Lower
Some low clearance vehicle stacked rocks. I wasn't going to take the time to move them.
Colorado River and Gold Bar Arch.
You made those obstacles look pretty easy! I've been over a few of those and they are definitely much more scary and difficult in person! 👏
Getting ready for Foutz Rear lower arm frame guards. A bit of emery cloth and some flat black paint I had kicking around I am pleased with the outcome. Looking forward to protecting it.
Slapped on some 50mm wheel spacers to get ready for the 3” RPG lift collers and 40” mickeys this Friday 😎
87.1 bore 6x135 M-14x1.5
More follow-up on the Moab trip . . .
Gold Bar Rim - Waterfall
(1st try)
Gold Bar Rim - Waterfall (2nd try)
  • #788
No. It is a Rough Country high winch mount (PN 51067).
The approach angle on that mount looks about perfect!
Did you air down any for these trails or did you keep the pressures up for for clearance?
The RC winch mount does not impact the OEM approach angle of 47°. When I was at the 43° wall obstacle, Poison Spider, the mount never touched the wall; even with a 1.5" fairlead and F55 flatlink.
I was aired down to 20-22 psig on all obstacles and trails.
  • #790
Have you considered going up to the 39-inch KO2s when you wear out the stock tires or are you content with the capabilities of the 37s?
When I bought the 🌶️ Raptor, I was/am pretty proud of saying ". . . other than that, it's completely stock." No changes to suspension, steering, engine or drivetrain; all the important stuff.
Short Answer: for about 2 seconds
Long Answer: 37" KO2s are heavy enough to move around, 105-lbs mounted. I would probably cuss lifting a 39" mounted tire onto the spare carrier. The 37s give the 🌶️ Raptor an average ground clearance of 14 inches. So far, I've found that to be sufficient for up to a hard 7 trail. Ask me again after I do some 8s. If I change anything, I'll probably go from the C rated 37s to a D rated 37 for better sidewalls. E rated might be too much?
I saw a lifted truck with 44" tires on the Golden Spike. It required a step ladder to get into the cab. Sure, it rolled over every obstacle like it wasn't there, but what's the fun in that? Besides, it needed to be trailered everywhere.
Bigger is not always better. Best to go with stock and learn better skills. 😜
  • #792
I can attest to the stock spare already being a royal PITA to remove and mount! The only way I can justify the 39s is going with a lightweight wheel like the RTR's. If you go that route I think the weight difference is pretty negligible considering the diameter improvement.
Are these 13.50? Look like 40 pizza cutters on the alignment rack.
Either way, these make me want to jump up in size where I’ve previously been debating dropping to 35s.
Yes 40x13.5x17
On 3” rpg collers
I have the rtr with 39 ko2s and it is about the same weight as the stock beadlock capable and 37 ko2s. ko2s are actually one of the lightest tires in their size. I have no issue taking off/ putting on my spare. its actually lighter than i thought it would be. I do live in the gym though :)
Wt. Delta = 16 lbs/each :cautious:
Cost Delta: $673 vs $418 :eek:
BFG comparison to Nitto and Falken.
I suppose if you went to a bigger rim, like 20", then you could reduce the weight some. But then you need new rims. 💸
