- May 25, 2022
- Sacramento/Tahoe
- 2022 Bronco Raptor
- Current Ride #2
As a fellow fiddler, I “installed” my Rock Slide Engineering EZ Rack spare tire mount.
As far as installations go this was super easy. If you can use a ratchet strap you can install this.
Also mounted a Rotopax DLX mount and 3 gallon gas container on each side.
Proper positioning of the mounts on the ratchet strap takes a little fiddling around. The final position was the sweet spot in solving for the following constraints:
1) Gas containers mounted as vertically as possible
2) Ability to open the tailgate without removing a gas container
3) Symmetrical (OCD issues)
4) Ability to FULLY open the tailgate without smashing the passenger side taillight or having to remove a gas container. It would be easy to damage your Raptor taillight if this isn’t resolved
5) Container not rubbing on tailgate, reinforcement panel or the third brake light pod
6) Ratchet strap maximally centered on the tire
I managed all except number 1, but they need to be positioned pretty much exactly like I did to achieve that. That said, they’re designed to lay flat so my fear of potential leaks is pure paranoia.
Overall, I’m very happy with this removable option to extend range on my very thirsty Raptor. I can also utilize the containers and DLX mounts on a potential future rack purchase If I go that direction later.
Still deciding how to manage the excess strap, probably a Velcro strap and a trim will do the trick.
